Date/Time: Thu, 02 May 2024 18:31:10 +0000
btc/usd historical quotes, how to get without crypto live account?
View Count: 881
[2018-08-07 09:32:01] |
User503358 - Posts: 50 |
If I have SC service package 5, may I get btc/usd historical quotes without any crypto exchange account?
[2018-08-07 23:51:56] |
In my service package 5 Bitmex servers are not included. What I need to do to start connection with Bitmex?
[2018-08-08 02:12:15] |
We think your service package should have access to the crypto currency data. We will check on this and get back to you.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-08 02:12:22
[2018-08-08 11:09:22] |
May be thats because I have 2 trading CQG accounts with AMP?
[2018-08-09 04:28:41] |
We apologize for the delay with this. The crypto currency data which is documented here: Cryptocurrency / Bitcoin Data and Trading Services Does require a direct account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-09 07:59:29] |
Now I have Bitmex account, but Sierrachart show me not enable on package. (see image) Reading Internal Order ID file. | 2018-08-09 07:46:27 Reading Trade Orders file. | 2018-08-09 07:46:28 Reading Trade Positions and Account Balance file. | 2018-08-09 07:46:28 Listening on UDP port 22904. | 2018-08-09 07:46:28 Software version: 1785 64-bit | 2018-08-09 07:46:28 Enabled for: Advanced Features. | 2018-08-09 07:46:28 Enabled for: Advanced Features 2. | 2018-08-09 07:46:28 Enabled for: Sierra Chart Historical Data Service. | 2018-08-09 07:46:28 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-08-09 07:46:28 Current selected Data/Trading service: CQG FIX Trading | 2018-08-09 07:46:28 Chart Update Interval: 500 | 2018-08-09 07:46:28 Data/Trade Service Settings automatically set. | 2018-08-09 07:46:28 Time Zone: +00:00:00 (UTC+00) | 2018-08-09 07:46:28 2018-08-09 00:46:28 Local computer time | 2018-08-09 07:46:28 2018-08-09 07:46:28 Local computer time in UTC | 2018-08-09 07:46:28 2018-08-09 07:46:28 Local computer time in SC Time Zone | 2018-08-09 07:46:28 2018-08-09 07:46:24 Server time in UTC | 2018-08-09 07:46:28 Local computer UTC time and Server UTC time difference: 2 seconds. | 2018-08-09 07:46:28 Program path: C:\SierraChart\ | 2018-08-09 07:46:28 Data Files path: C:\SierraChart\Data\ | 2018-08-09 07:46:28 OS Version Number: 6.3 | 2018-08-09 07:46:28 Locale Setting: C | 2018-08-09 07:46:28 Checking for new symbol settings for service code cqg | 2018-08-09 07:46:28 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-08-09 07:46:28 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-08-09 07:46:28 Requesting symbol settings for service code cqg. Overwrite = on. | 2018-08-09 07:46:29 Received 5 login tokens. | 2018-08-09 07:46:29 Symbol settings received. | 2018-08-09 07:46:29 Processed 1335 symbol settings. | 2018-08-09 07:46:30 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-08-09 07:46:30 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-08-09 07:46:30 HTTPS connection to login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-08-09 07:46:31 HTTPS connection to login.sierrachart.com:443 (1) | Received socket Close event. | 2018-08-09 07:46:31 HTTPS connection to login.sierrachart.com:443 (1) | Initiating close of socket by core. | 2018-08-09 07:46:31 HTTPS connection to login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-09 07:46:31 HTTPS connection to login.sierrachart.com:443 (1) | Closed. | 2018-08-09 07:46:31 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-09 07:46:33 CQG FIX socket (6) | Creating socket. Using TLS 1.2. | 2018-08-09 07:46:33 CQG FIX socket (6) | Connecting to IP: 208.48.16.214. | 2018-08-09 07:46:33 CQG FIX: Sending the Logon message. | 2018-08-09 07:46:33 CQG FIX Trading | Connected to trading server. | 2018-08-09 07:46:33 CQG FIX Trading | Connecting to server api.cqg.com | 2018-08-09 07:46:33 CQG WebSocket | Connecting to WebSocket server. | 2018-08-09 07:46:33 CQG FIX | FCM name: AMP | 2018-08-09 07:46:34 CQG WebSocket socket (7) | Creating socket. Using TLS 1.2. | 2018-08-09 07:46:34 CQG WebSocket socket (7) | Connecting to IP: 195.166.124.165. | 2018-08-09 07:46:34 CQG WebSocket | Opening WebSocket. | 2018-08-09 07:46:34 CQG WebSocket | Sending WebSocket handshake. | 2018-08-09 07:46:34 CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-08-09 07:46:34 CQG WebSocket | Header line. Connection: upgrade | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-08-09 07:46:34 CQG WebSocket | Header line. Sec-WebSocket-Accept: yvVebq1/9KZC252/JvzgZGQ1JTY= | 2018-08-09 07:46:34 CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-08-09 07:46:34 CQG WebSocket | Header line. Upgrade: websocket | 2018-08-09 07:46:34 CQG WebSocket | Header line. | 2018-08-09 07:46:34 CQG WebSocket | Web socket state is now open. | 2018-08-09 07:46:34 CQG FIX Trading | WebSocket connected. | 2018-08-09 07:46:34 CQG FIX Trading | Sending market data logon message. | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-08-09 07:46:34 CQG FIX Trading | Base Time: 2018-08-04T03:58:04. 2018-08-04 03:58:04 | 2018-08-09 07:46:34 CQG FIX Trading | Logon successful. Session Token = BjwNZeVVrMFfaz6pgQn1x1A6hAyHqkSltFEw7xP0HVg2IYjg4Wk4Hw+foP6S2wzzVH/G45F9zKO | 2018-08-09 07:46:34 CQG FIX Trading | Connected to data and trading server. | 2018-08-09 07:46:34 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-08-09 07:46:36 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-08-09 07:46:36 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-08-09 07:46:36 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-09 07:46:36 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-08-09 07:46:36 CQG FIX: DisconnectFIX called. | 2018-08-09 07:47:33 CQG FIX: Sending a Logout message. | 2018-08-09 07:47:33 CQG FIX Trading | Sending Web API Logoff message. | 2018-08-09 07:47:33 CQG WebSocket socket (7) | Adding bytes from final send buffer from buffered socket: 17 | 2018-08-09 07:47:33 CQG WebSocket socket (7) | Initiating close of socket by core. | 2018-08-09 07:47:33 CQG WebSocket | WebSocket closed. | 2018-08-09 07:47:33 CQG FIX Trading | WebSocket closed. | 2018-08-09 07:47:33 CQG WebSocket socket (7) | Sending bytes from final send buffer: 17 | 2018-08-09 07:47:33 CQG FIX Trading | Disconnected. | 2018-08-09 07:47:33 CQG WebSocket socket (7) | Write in progress. Shutdown being delayed. | 2018-08-09 07:47:33 CQG FIX socket (6) | Initiating close of socket by core. | 2018-08-09 07:47:33 CQG FIX socket (6) | Write in progress. Shutdown being delayed. | 2018-08-09 07:47:33 CQG WebSocket socket (7) | Write has completed. Shutdown being performed. | 2018-08-09 07:47:33 CQG WebSocket socket (7) | Shutdown started. Waiting for graceful close. | 2018-08-09 07:47:33 Checking for new symbol settings for service code bitmex.exchange.trading | 2018-08-09 07:47:33 Current selected Data/Trading service: BitMEX Trading Direct | 2018-08-09 07:47:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-09 07:47:33 HTTPS connection to www.sierrachart.com:443 (9) | Creating socket. Using TLS 1.2. | 2018-08-09 07:47:33 HTTPS connection to www.sierrachart.com:443 (9) | Connecting to IP: 204.15.192.108. | 2018-08-09 07:47:33 CQG WebSocket socket (7) | Socket gracefully closed by remote side. | 2018-08-09 07:47:33 CQG WebSocket socket (7) | Closed. | 2018-08-09 07:47:33 CQG FIX socket (6) | Write has completed. Shutdown being performed. | 2018-08-09 07:47:33 CQG FIX socket (6) | Shutdown started. Waiting for graceful close. | 2018-08-09 07:47:33 CQG FIX socket (6) | Socket gracefully closed by remote side. | 2018-08-09 07:47:33 CQG FIX socket (6) | Closed. | 2018-08-09 07:47:33 Requesting symbol settings for service code bitmex.exchange.trading. Overwrite = on. | 2018-08-09 07:47:33 Symbol settings received. | 2018-08-09 07:47:33 Processed 6 symbol settings. | 2018-08-09 07:47:34 Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2018-08-09 07:47:36 * BitMEX Trading Direct | Disconnected. | 2018-08-09 07:47:36 HTTPS connection to www.sierrachart.com:443 (9) | Socket gracefully closed by remote side. | 2018-08-09 07:47:38 HTTPS connection to www.sierrachart.com:443 (9) | Initiating close of socket by core. | 2018-08-09 07:47:38 HTTPS connection to www.sierrachart.com:443 (9) | Received socket Close event. | 2018-08-09 07:47:38 HTTPS connection to www.sierrachart.com:443 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-09 07:47:38 HTTPS connection to www.sierrachart.com:443 (9) | Closed. | 2018-08-09 07:47:38 Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2018-08-09 07:48:26 * |
Data_Trade+Service+Settings+2018-08-09+00.52.48.png / V - Attached On 2018-08-09 07:59:21 UTC - Size: 60.5 KB - 245 views |
