Date/Time: Sun, 28 Apr 2024 12:47:24 +0000
cTrader FIX API connection
View Count: 2791
[2018-08-07 05:07:33] |
User40642 - Posts: 8 |
Dear developer, I think its time to develop cTrader connection FIX API into your data service connection tab! Because 2 years ago cTrader platform has FIX API connection details, available for free! Will you do that in short time? Regards |
[2018-08-31 10:22:59] |
BeardPower - Posts: 51 |
It seems that the SC guys did not see that post.
[2018-08-31 16:35:43] |
Yes but this is not something we can spend any time on now.
[2021-01-14 12:37:18] |
mazzy /| blast - Posts: 54 |
Any plans to support cTrader connection ? Since it was mentioned to cover free FIX API I’m about to use a 3rd party bridge but it doesn’t make me happy that it’s unofficial |
[2021-01-14 17:08:51] |
No this was looked into and clearly decided against because they do not provide the technical design that we require.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-14 17:09:34
[2022-06-11 23:37:53] |
virtualcointrading - Posts: 39 |
cTrader FIX API connection | Post: 247332 mazzy /| blast > which 3rd party bridge are you using? |
