Date/Time: Tue, 14 May 2024 13:52:54 +0000
Which DataFeed/Broker Combination will work
View Count: 616
[2018-08-07 01:03:16] |
TraderJack - Posts: 3 |
Hello, Been trialing SC for a month now and I have a question about which datafeeds I should purchase. I trade Stocks and Forex using Interactive Brokers. I'm currently using SC as a front end for IB and have it setup to use IB for trading data feed for stocks and a few currencies. I primarily use the DOM to trade stocks and like it quite a bit. I subscribe to the IB package that gives me "top of book" which doesn't show me the L2 quotes unfortunately but is at least real-time. What I want is to be able to see the orderbook not just the top orders. I'm trying to determine if I should get the IB L2 quotes or something else? Which feed is going to provide me with the data I want? The SC feed doesn't provide L2 quotes I believe? Is there an alternate that does which might be better than IB? I am also not opposed to switching to another broker if it is as economical as IB, but which integrates better with SC? Regards, |
[2018-08-07 01:37:31] |
For stock level 2 data from Interactive Brokers, refer to: Interactive Brokers Trading Service: Accessing Level 2 / Market Depth Data for Stocks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-07 06:23:14] |
I apologize if I was not clear. I have read the IB page and know I CAN use IB L2 data. What I was wondering was if there was a better/alternate solution?
[2018-08-07 06:25:18] |
We really do not have anything else that Sierra Chart supports that provides level 2 Equities data.
