Date/Time: Thu, 02 May 2024 08:20:29 +0000
Cumulative Relative Volume
View Count: 970
[2018-08-06 22:50:13] |
CTBSD - Posts: 10 |
There has to be a study for a basic 10 day Cumulative Relative Volume. I have one in TradeStation, had one in Sierra but after reformatting my computer it doesn't work. I am trying to attach a picture showing what a true Cumulative Relative Volume looks like.
Cumulative Relative Volume.png / V - Attached On 2018-08-06 22:49:01 UTC - Size: 9.69 KB - 305 views Attachment Deleted. |
[2018-08-06 22:52:01] |
CTBSD - Posts: 10 |
I copied all the files from the old computer but still get this erro. Reading Internal Order ID file. ESU18 [CB] 5 Min #6 | Error loading Custom Studies DLL: C:\SierraChart\Data\relVolume_64.dll. Windows error code 126: The specified module could not be found. | 2018-08-06 18:50:59 * |
[2018-08-08 02:54:56] |
If that particular file, C:\SierraChart\Data\relVolume_64.dll, is actually present, then this would indicate that a dependent file it requires is missing. You need to contact the developer about this. Have a look at the Sierra Chart provided Relative Volume study as an alternative: Relative Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-08 02:55:35
