Date/Time: Wed, 08 May 2024 00:00:16 +0000
IQ Feed data with Sierra
View Count: 1284
[2013-10-19 15:58:34] |
garywed - Posts: 1 |
Using IQ Feed with Sierra. Have historical daily chart set to update continuously. Current day bar does not seem to close at normal session close times but keeps updating. The following morning when Sierra is restarted it has adjusted and bar is correct. Is this an issue with Sierra or IQ Feed?
[2013-10-21 00:23:13] |
User14266 - Posts: 225 |
I experience this with CTS also.
[2013-10-21 00:31:57] |
This help topic explains how all of this works: Http://www.sierrachart.com/index.php?l=doc/helpdetails12.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
