Date/Time: Wed, 15 May 2024 23:10:19 +0000
bitcoin
View Count: 693
[2018-08-06 17:58:06] |
Ed Meckelborg - Posts: 71 |
What is the futures symbol for Nov bitcoin. Can I chart it on Sierra Charts? |
[2018-08-06 18:00:53] |
On what exchange? Yes you can chart this.
[2018-08-06 23:22:50] |
I do not know where bitcoin trades, I would like the symbol so that I can chart it using SC
[2018-08-07 02:48:17] |
We recommend using BitMex. Refer to: BitMEX Trading Service For market data only, refer to: http://www.sierrachart.com/index.php?page=doc/CryptocurrencyDataServices.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
