Date/Time: Mon, 06 May 2024 10:44:21 +0000
Charts are not updating. Message log shows connected to realtime updates.
View Count: 1155
[2013-10-19 05:48:58] |
reggytrades - Posts: 29 |
I have had some "man in the middle" attacks in the past. Possible my account has been hacked. If sent the log would that help? Can you recommend a security/encryption/firewall solution or provider? Fixed, thanks. Date Time Of Last Edit: 2013-10-19 09:32:41
[2013-10-19 19:02:48] |
If Intraday charts are not updating, refer to help topic 3 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
