Date/Time: Thu, 02 May 2024 22:10:39 +0000
sc.GetInternalPosition doesnot work in new version sierrachart
View Count: 1246
[2013-10-19 03:12:24] |
xfighter - Posts: 36 |
I just updated my sierrachart to version 1032. It seems that sc.GetInternalPosition function is not there any more. Should I use sc.GetTradePosition instead? Thank you! |
[2013-10-19 03:58:24] |
Yes. It has been renamed to sc.GetTradePosition.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-19 03:58:33
