Date/Time: Wed, 15 May 2024 01:02:17 +0000
Desktop configuration for big spreadsheet.
View Count: 649
[2018-08-04 22:46:47] |
User503358 - Posts: 50 |
How much RAM needed for open spreadsheet with volume by price data from jan.2011, for example, for Gold futures, ~200 000 row? I try with 32GB RAM. Spreadsheet opens without full VbP or crashes (out of memory). I need suggestions!
[2018-08-05 01:51:07] |
We do not know. You need to look the memory use in the Operating System Task Manager.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-05 09:53:44
[2018-08-05 09:07:07] |
I checked, the program uses only 5GB of 32GB RAM (15%): gives 'out of memory error' and loads not all VbP data (~first 10% of rows are with VbP). How can I make the program use more memory or this is not RAM problem?
Virtu32.png / V - Attached On 2018-08-05 09:06:21 UTC - Size: 36.07 KB - 238 views Virtu32_2.png / V - Attached On 2018-08-05 09:06:28 UTC - Size: 76.63 KB - 249 views Virtu32_3.png / V - Attached On 2018-08-05 09:06:34 UTC - Size: 32.23 KB - 220 views |
[2018-08-05 09:55:23] |
Make sure you are running the 64-bit version of Sierra Chart and that you are running the current version. Refer to: Software Download: Difference Between 32 and 64-bit Versions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-05 12:10:54] |
Is in the current version functionality of spreadsheet remain like in the old versions? ref: Volume at price data is not displayed correct in the spreadsheet! |
[2018-08-05 14:21:19] |
version 1708 64-bit work well for this purpose, min 16GB RAM needed.
