Date/Time: Tue, 14 May 2024 14:27:00 +0000
Cloud server
View Count: 2120
[2018-08-04 16:15:01] |
User704778 - Posts: 1 |
Is it possible to upload sierra to a cloud server so I can log on and trade it from different locations while I am travailing and will you recommend a cloud service? Thanks
[2018-08-05 05:41:28] |
Yes of course. You just need a VPS or preferably a dedicated server running Windows. And use Windows Remote Desktop protocol program to connect to it. You can also use your own home computer if you have a good stable Internet connection. And also connect to it with Remote Desktop protocol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
