Date/Time: Fri, 03 May 2024 04:23:46 +0000
keyboard scrolling
View Count: 1097
[2013-10-19 02:15:35] |
Todd - Posts: 62 |
I like to scroll through my charts (horizontal/time) frequently throughout the day. I am keyboard oriented and want to avoid using the mouse to scroll. Is there a way to scroll say n bars back/forward with a keystroke (combination)? Ideally I could set small and big scroll config parameters and bind them to some keystrokes. I see I can scroll via keyboard back and forward one whole screen at a time. This is much too large a scroll for me. If you can't support a configurable value, then I would like to see a half-screen scroll introduced that I could bind (as a simpler solution). Thanks. |
[2013-10-19 05:06:46] |
This is what you are looking for: https://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#ScrollMultiplier Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-19 13:48:33] |
Todd - Posts: 62 |
That is exactly what I wanted. Thanks. One small annoyance is that when I am at the end of a chart, when I enter my scroll key combo, it only scrolls one bar instead of the configured amount (0.4 screens). |
