Date/Time: Thu, 16 May 2024 00:58:28 +0000
Horizontal line tool
View Count: 1333
[2018-08-03 15:17:10] |
Dennis B. - Posts: 263 |
Would like to add the horizontal line tool to my control bar. Can't seem to find it when I go to customize it.
[2018-08-04 01:09:52] |
You will find it in Global Settings >> Customize Control Bars >> Control Bar #>> Available Control Bar commands >> Tools >> Horizontal Line Tool.
[2018-08-05 20:54:45] |
It's buggy, not there all the time and when it is, it shows a horizontal ray. Running 81
[2018-08-05 20:58:43] |
There definitively is no bug. That cannot be. Once it has been added to the Control Bar you will not see it listed in the list of available buttons. Check the list on the right.
[2018-08-06 13:06:23] |
Can I add another horizontal line tool to my control bar....so I would have 2 ? Or does your program only allow 1 command of the available commands ?
[2018-08-06 15:59:23] |
No that is not allowed.
[2018-08-06 16:38:00] |
Is there a work-around, can I add another control bar and put it in there ?
[2018-08-06 16:42:35] |
Don't respond. It works.
