Date/Time: Tue, 14 May 2024 21:09:57 +0000
[Programming Help] - Study calculation time gets longer and longer
View Count: 658
[2018-08-02 22:03:56] |
User53601 - Posts: 105 |
Hello, I have programmed more than 15 studies for my trading so far. Now I have got an issue with one of them. Always when I do recalculation of all studies via Analysis/Studies/ OK or APPLY button the calculation time of one of the studies gets ever longer. It looks like this: first calculation takes 40 ms then I make recalculation by APPLY button, calculation takes 80 ms. another use of Apply button takes 150 ms, then 200 ms, and so on. I do not have a clue what is wrong with the code. Could you give me a hint where should I focus to search for the reason of this behaviour? Thank you |
[2018-08-04 00:58:15] |
You really just have to examine the code and see where you have loops of processing and seeing if those iterations are just getting greater and greater. It is hard for us really to say. This is just one suggestion.
[2018-08-06 06:58:04] |
@sstfrederik - Posts: 403 |
In my experience this can sometimes happen on studies when you have sc.FreeDLL set to 1. Frederik simplesystemtrading.com |
