Date/Time: Sat, 18 May 2024 15:56:51 +0000
how to set multiple target bracket orders for forex trades
View Count: 1132
[2018-08-02 00:38:55] |
User276793 - Posts: 48 |
how to set multiple target bracket orders for forex trades I have been trying to figure this out for some time but can never get the stops to work correctly and the position size keeps jumping back to 1, 2 like i was trading futures contracts not forex. I am entering 200000 at a target for each order but says stop does not match. I have only been trading futures on the platform so far. the more detailed the answer the better=) thanks |
[2018-08-06 20:52:02] |
Refer to the instructions here: Attached Orders: Using Attached Orders and Attached Order Settings And here: Attached Orders: Multiple-Bracket Example Make sure you have all of the quantities set correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-30 17:24:47] |
all figured out thanks!
