Date/Time: Mon, 20 May 2024 14:54:08 +0000
TPO Profile Midpoint marker randomly missing in Version 1781
View Count: 1310
[2018-08-01 21:26:56] |
User68474 - Posts: 195 |
I've noticed since upgrading to Version 1781 that my MidPoint marker ("Highlight MidPoint in Profile")for my traditional, classic Letter-based 30 minute TPO profiles goes missing whenever I "split out" (i.e."Letter Blocks in Own Columnn)my Profiles. This also happens when I choose to "Split Profile here", which should show the mid-point for those time periods which have been split off. However, when scrolling back and testing each session (Day/Evening) going back a few days, I see that on a few (less than half, I approximate))of them, it does remain after splitting out. Can't correlate the randomness. Never had this happen over the past years. This is very important for many of us. Will appreciate your checking into this.
[2018-08-02 05:10:43] |
We will look into this but not likely we will get to it until next week.
[2018-08-10 17:32:56] |
Hi...just checking at week's end to see if you've had a chance to take another look at this. I know how swamped you are.
[2018-08-13 17:26:06] |
We will be getting to this, either today or the next couple of days.
[2018-08-13 20:26:23] |
John - SC Support - Posts: 31741 |
We have updated the Midpoint for TPO Profiles to show the Midpoint marker regardless of where it falls in the data columns. What you were seeing previously was that if the TPO Profile was displayed with the data in their own columns, then the Midpoint marker would only show if it was in the first column. This will be in the next release - 1789. When available, you can update using the following instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
