Date/Time: Thu, 23 May 2024 16:53:13 +0000
Chart candles are distorted
View Count: 638
[2018-08-01 18:33:26] |
User420112 - Posts: 1 |
Hi, For some reason my candles are slightly distorted. I have checked settings but cannot find any reason why this would be the case. I would be grateful if you could please look into the matter. Kind regards BL. http://www.sierrachart.com/image.php?Image=1533148372749.png |
F.US.CLEU18 [CV] 10 Sec #3 2018-08-01 19_29_05.863.png / V - Attached On 2018-08-01 18:29:47 UTC - Size: 129.82 KB - 245 views Attachment Deleted. |
[2018-08-01 19:01:50] |
From our perspective we do not know what is meant by distorted and specifically where on that chart there is a problem. You might want to select Chart >> Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
