Date/Time: Sat, 18 May 2024 05:24:40 +0000
Market Depth Historical not showing into fill space
View Count: 842
[2018-07-31 18:48:14] |
nosast2 - Posts: 73 |
Since I suppose version 1784 the depth is not extended into the fill space. Also the setting for % fill space doesn't change anything. Going back to 1781 everythings fine. |
Unbenannt.PNG / V - Attached On 2018-07-31 18:47:54 UTC - Size: 5.1 KB - 264 views Attachment Deleted. |
[2018-07-31 19:50:24] |
We will look into this and resolve. But allow a few days. This is related to performance improvements with the Market Depth Historical Graph feature.
[2018-07-31 22:36:00] |
No problem... Take your time. Performance improvements with the Market Depth Historical Graph feature are highly welcome! Whenever I use this feature Sierra slows down quite significantly. The CPU and RAM usage are still fine (below 20%) but there seems to be an issue with the graphics and/or the transparency of those. Setting the Update intervall to 250ms or higher helps but it's kind of a bad solution because not only the indicator gets delayed but also the update of the price feed. Maybe Sierra can use more power from the GPU for Market Depth like Bookmap does? |
[2018-07-31 23:19:08] |
Yes we do plan some additional performance improvements and also when we support OpenGL the GPU will be used more. That should be coming before the end of the year.
[2018-08-01 06:19:24] |
Sounds great!
[2018-08-01 17:52:20] |
Jeffrey - Posts: 2103 |
This issue should be fixed in the next release.
