Date/Time: Sat, 18 May 2024 09:05:31 +0000
Trading DOM/Ladder Trail /Tail
View Count: 809
[2018-07-31 17:20:32] |
Ryan Bailey - Posts: 51 |
Hi guys I was wondering if you could add a Tail to the DOM/Ladder showing the last (100-150) trades and where they have been. this kinda gives you an idea how the money is flowing and in what direction.. just another helpful confirmation on top of the charting. I added a picture of a Ladder that has this function that i really like. Hoping to have this feature on SC. Please let me know how to add this is its already functional. Thanks Ryan |
[2018-07-31 17:43:21] |
We really just recommend using a standard chart for this. You can always detach it, resize as needed, and place it by the Trading DOM.
[2018-07-31 18:44:03] |
So does this mean this function is not a possibility or is not currently an option? Seems like something easy to implement that may give your users a helpful edge. if its not something that you currently offer do you think it could be somethign to add tot he future list of things to do?
[2018-07-31 19:40:43] |
Actually, our answer really was not the best. This functionality does exist but you just need to use a standard chart enable the Chart DOM: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM This is all that we offer and nothing further will be added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
