Date/Time: Sun, 19 May 2024 00:37:43 +0000
Same Charts - New Feed Supplier
View Count: 643
[2018-07-31 15:11:29] |
User481114 - Posts: 17 |
Hi, I'm changing feed suppliers...which leads me to believe that I must start some new "instance".....However, I do not want to rebuild all new charts. Is there a way to "import" charts to the new instance? Some instruments won't exist...but I suppose I can just delete those regions.....and there's the issue of changing the instrument names? I'm a new subscriber, and really don't want to re-invent the wheel here !! Thanks |
[2018-07-31 20:40:22] |
If you are not going to continue to use the existing Data or Trading service you currently are, then you just need to set Sierra Chart to use the new service through Global Settings >> Data/Trade Service Settings. Instructions for each service are documented here: Supported Data and Trading Services And follow the instructions here to change the symbols of the charts in your existing Chartbooks: Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-31 20:41:27
