Date/Time: Sat, 04 May 2024 11:11:24 +0000
[User Discussion] - Study: Get data other Symbol
View Count: 1089
[2013-10-18 16:01:10] |
User90564 - Posts: 2 |
Hi, How to get datas (Ask, Bid etc...) other symbols. Example: My Study is running EURUSD, and Can I get ASK price from USDCHF? Other side, Can I send buy/sell order another symbols? Example: My Trading Study is running EURUSD and I'd like to send order USDCHF. Is it will be work? Thanks. |
[2013-10-18 19:01:20] |
Neither of these are very straightforward to do. There are techniques, but this is outside the scope of our support. We can only refer you to the documentation and you need to see what is available to see how to accomplish this: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-18 21:43:23] |
Which is very easy to do, and how?
[2013-10-18 21:57:04] |
You will need to have a chart open for each symbol you want to get data for and submit orders for. You may want to use persistent variables and use the function for getting persistent variables from other charts, as a method to communicate between charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-18 21:57:15
