Date/Time: Sun, 19 May 2024 22:10:51 +0000
VolumeByPrice from ASCIL
View Count: 541
[2018-07-26 20:27:44] |
User132748 - Posts: 159 |
Is there any way to draw VolumeByPrice study (as tool) via ASCIL? I dont see this drawing type in sc.UseTool() function but I did use data from already drawn profiles. Thanks
[2018-07-26 22:15:33] |
No.
[2018-07-27 07:17:56] |
Any plans for this feature? You have VbP available as tool already. So looks quite easy to add that as drawing type for sc.UseTool()? Just define BeginIndex and EndIndex as inputs. Thanks
