Date/Time: Sun, 19 May 2024 22:32:16 +0000
usdjpy data
View Count: 614
[2018-07-26 14:51:20] |
TheFibber - Posts: 81 |
it's a lot of time usdjpy from your server didn't update...the following is the log HD Request # 2 | Error downloading historical Intraday data for USDJPY. Historical data logon error: Data files folder not set for service code: ice.eu | 2018-07-26 10:48:37 Historical data download thread signaled to stop. | 2018-07-26 10:48:37 Socket (7) | Shutdown started. Waiting for graceful close. | 2018-07-26 10:48:37 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USDJPY | 2018-07-26 10:48:37 HD Request # 2 | Completion time: 0s | 2018-07-26 10:48:37 HD Request # 2 | Intraday data download complete for USDJPY. Unique request ID: 1 | 2018-07-26 10:48:37 Removed historical data download ID 1 | 2018-07-26 10:48:37 Real-time Intraday chart data file updates started for USDJPY | 2018-07-26 10:48:37 Opened cached Intraday file: C:\SierraChart2\Data\USDJPY.scid | 2018-07-26 10:48:37 Intraday chart data file opened for USDJPY | 2018-07-26 10:48:37 Socket (7) | Socket gracefully closed by remote side. | 2018-07-26 10:48:37 Socket (7) | Closed. | 2018-07-26 10:48:37 |
[2018-07-26 17:53:10] |
There is a problem with the Symbol Settings. Perform a Full Reset of the Symbol Settings: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps After this fully re-download the data in the chart by going to the chart and selecting Edit >> Delete All Data and Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-26 17:55:02
