Date/Time: Sun, 19 May 2024 22:32:12 +0000
Display P/L in Currency Value 4 decimal places
View Count: 584
[2018-07-26 04:18:00] |
User852086 - Posts: 41 |
Is it possible to display P/L in Currency Value at 4 decimal places? The DOM only displays two decimal regardless of the settings.
[2018-07-26 04:24:30] |
No not currently. Typically there has not been a need for this level of detail but if there is a need we can always add a setting for this.
[2018-07-26 05:10:00] |
This feature will be very useful for crypro. Is there any other alternative? The trade activity logs also displays only two decimal places. It's difficult to determine correct calculations during backtesting
