Date/Time: Tue, 21 May 2024 17:03:25 +0000
sc.GetUserDrawingByLineNumber()
View Count: 652
[2018-07-25 14:31:10] |
kas64h - Posts: 87 |
I'm having a problem with the sc.GetUserDrawingByLineNumber() function whereby the s_UseTool structure returned has its ChartNumber member always set to 0 Every other member - LineNumber, BeginIndex, EndIndex etc. etc. is all set fine, it's just ChartNumber continually comes back as 0 (I'm clearing the s_UseTool structure before passing it to the function) I would have expected the s_UseTool structure ChartNumber to be set to the Chart Number the Drawing is on, as is the case with the sc.GetUserDrawnChartDrawing() function. I'm using Sierra version 1784. Thanks |
[2018-07-25 17:58:58] |
Support for setting the ChartNumber when using this function will be added to the next release.
