Date/Time: Sat, 10 Oct 2026 12:08:39 +0000
sc.RecalculateChart()
View Count: 1201
| [2018-07-24 18:19:07] |
| kas64h - Posts: 87 |
I've been trying to use the sc.RecalculateChart(int ChartNumber) function, but without success. It looks as though the chart associated with SCStudyInterfaceRef sc is being recalculated (i.e. sc.ChartNumber), rather than the chart specified by the ChartNumber parameter. I've done several tests, and referenced the Sierra scsf_ChangeStudyInputExample example in the studies2.cpp, but the results are the same. I'm using Sierra version 1784. Thanks |
| [2018-07-24 18:44:20] |
We see why this is a problem and it will be resolved in the next release.
| [2019-03-15 21:44:42] |
| wwwingman - Posts: 185 |
Hi, I wonder if I don't have the same problem. I am using the 1882 version. -- W |
| [2019-03-15 21:57:59] |
No, that could no longer be the case.
