Date/Time: Sun, 19 May 2024 23:32:45 +0000
Pivot Points Variable Period
View Count: 1862
[2018-07-23 18:32:00] |
User635423 - Posts: 51 |
I am using this study and I have the time period set to weeks. I would like to see a weekly pivot on all time frames not just weekly. Is this possible? Thanks |
[2018-07-23 18:36:31] |
Yes this is possible. If you are referring to the time period of the chart bars those can be set to any timeframe but not longer than 1 week. Not sure why the question is being asked because you should not see any issue.
[2018-07-24 13:24:06] |
I am not referring to the time period of the chart bars. I would like to see weekly pivot on all time frames not only on weekly. Is it possible to see a weekly pivot on an 60 min chart as well as other chart types? Thanks, |
[2018-07-24 17:13:29] |
Yes you can do this. You need to use the Pivot Points-Variable Period study. What are the Input settings you have set that study to?
[2018-07-25 15:54:39] |
Hi, For the Pivot Points-Variable Period study the only input setting I changed was time period type to weeks. All other setting remain unchanged. Thanks, |
[2018-07-25 19:25:36] |
Provide that particular chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-26 12:31:13] |
I cannot upload a copy of the chart. In settings the only setting I have changed is the time period type to weeks. All other settings have not been touched. All I am trying to do is see the weekly pivot point on other time frames as well not just the weekly time frame. For example, I would like to see a weekly pivot point applied to a 15 min and a 1 hour time frame. How can I do this? Thanks again! |
[2018-07-26 18:40:49] |
Here is an example: http://www.sierrachart.com/image.php?Image=1532630289126.png We attached a chartbook. Here are instructions to use it: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
WeeklyPivotPoints.Cht - Attached On 2018-07-26 18:39:32 UTC - Size: 29.96 KB - 290 views |
