Date/Time: Sun, 19 May 2024 22:50:45 +0000
ACSIL - Unable to write .dll using MS Visual Studio & sc.FreeDLL
View Count: 1838
[2018-07-22 22:19:04] |
User486568 - Posts: 10 |
I am having trouble using the development mode of sc.FreeDLL = 1; when using MS Visual Studio for my editor and building.When using the same exact source code it will allow the dll to reload fine if I use the Sierrachart remote building tool. Here is the error messages I get when trying to rebuild: Severity Code Description Project File Line Suppression State
Error LNK1104 cannot open file 'C:\SierraChart\Data\MJG2CustomStudies.dll' MJG2CustomStudies C:\Users\stitch\source\repos\MJG2CustomStudies\MJG2CustomStudies\LINK 1 I've tried with both Release & Debug and neither seem to allow rewriting the dll file. |
[2018-07-24 15:18:16] |
User735640 - Posts: 14 |
I had this issue once when I was trying to set the value to "1" when the value was already set to "0". I first had to remove the dll study from all charts it was applied to and then compile it with VS. After it compiled and was added back to the chart. I was then able to debug the dll and make inline code changes with no problems. |
[2018-07-24 18:33:37] |
Refer to this section here about this: Advanced Custom Study Interface and Language (ACSIL): Modifying Advanced Custom Study Code I first had to remove the dll study from all charts it was applied to and then compile it with VS. You actually just need to restart Sierra Chart after changing that setting.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-24 18:34:31
[2018-07-24 19:36:43] |
I never had it set to sc.FreeDLL = 0; - I definitely tried restarting SierraChart (in fact I had to in order to have any subsequent builds of the dll work.Any other things I should check? |
[2018-07-24 20:10:25] |
But make sure every function within the DLL uses sc.FreeDLL = 1;
[2018-07-24 22:58:24] |
There is only one function - this is a super simple test just trying to get the basics working.
[2018-07-26 16:52:59] |
We do not know what the problem is. It would seem like the DLL is not getting released. If you do not experience this with Remote Build, then it could not be an issue on our side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-26 16:53:09
