Date/Time: Sun, 05 May 2024 13:22:07 +0000
Chart Viewing
View Count: 1196
[2013-10-17 22:41:48] |
User14178 - Posts: 2 |
I'm writing to tell you that I'm having difficulties moving around a chart to view areas of interest using the scale range and interactive scale range buttons. I don't find these options very intuitively obvious and I'm spending a large amount of time just trying to move around the chart rather than focusing on my trading. I've used Trade Navigator before and I think the way they have the program set up to view different areas of a chart is a lot better. Maybe Sierra Chart might be able to improve this aspect of the program. Other than this I enjoy using Sierra Chart and am happy with it's capabilities.
[2013-10-17 23:16:19] |
Have a look at the Hand tool. That's probably what you are looking for: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
