Date/Time: Sat, 04 May 2024 01:38:04 +0000
SC x64
View Count: 840
[2018-07-21 19:41:39] |
Crtfyd - Posts: 277 |
I noticed when looking at my Windows Defender list, I wanted to make sure SC was included in the "Exceptions" I noticed (see attached pic) that two SC's are open. I have my normal SC open. In SC>Help>"About", it says 32 bit. I could've sworn I downloaded the 64 bit version (I obviously did, but I thought that was the one I was using.) Are those TWO Sierra Charts supposed to be Open? I'd prefer using the 64 bit, but what Ive read from your info, that it doesn't make a big difference, unless I'm writing a lot of code. (I'm not, unless you count using the Simple alerts provided (I have over 80 studies running in my Studies Windows). Is there a potential problem with both of them accessed? IS my Taskbar icon opening both? (I didn't think I had to erase the 32bit b4 downloading the 64) |
SIerra Charts Exceptions.jpg / V - Attached On 2018-07-21 19:39:07 UTC - Size: 927.04 KB - 285 views |
[2018-07-21 21:12:35] |
This is explained here: Software Download: Difference Between 32 and 64-bit Versions You can use either the 32 or 64 bit version and both are present at the same time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-21 21:12:42
[2018-07-24 14:31:52] |
Thanks for your reply. Some FYI I noticed for the systems. 1- I ran both 32 and 64 bit systems separately at different times/days and noted their performance in Task Manager, 32 bit= 25% CPU, 382% memory 64 bit= 25% CPU, 218% memory For my 6RAM, i3, 64bit WIN10 laptop, the 32 bit performed better....or did it? My question is, I have read on some blogs that it running MORE memory is actually better bc its accessing more to help run. This doesn't make sense to me, thinking if it needs it, it will use, therefore more memory used is bad. Can you clear this up? 2-Also I noticed that on the 32 bit only, it has this annoying pop up of "Save All" after I closed my TA DOM (did nothing with charts, just finished trading, but want my charts to remain open) Minor annoyance since I can just click no, but at times it can be confusing as to did it mean "Save ALL" to the DOM (yes, I know the DOM has a save all too, but this is a pop up on SC). So at times Ive clicked yes and it closed out my SC unnecessarily. It doesn't do it on the 64 bit. Regards |
[2018-07-24 17:53:07] |
2. You will need to contact Transact about this. Your other questions are not within the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
