Date/Time: Sat, 04 May 2024 10:29:21 +0000
Can I make trade entries with Excel but Exits on your trailing stop?
View Count: 816
[2018-07-23 20:27:54] |
You would need to use the Advanced Custom Study Interface and Language which uses C++, to develop an interface to your Excel trading system. Refer to: Advanced Custom Study Interface and Language (ACSIL) And then once you get a trade signal from your system, you could then submit an order using the ACSIL trading functions: Automated Trading From an Advanced Custom Study And then you can use the trailing stop functionality in Sierra Chart. All of that is documented on the page linked above. There is currently not a way to programmatically fill in Sierra Chart spreadsheets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
