Date/Time: Thu, 02 May 2024 03:37:08 +0000
Volume at price data is not displayed correct in the spreadsheet!
View Count: 991
[2018-07-20 14:33:59] |
User503358 - Posts: 50 |
From today I can't open spreadsheet with Volume at price data correct. What I do wrong? http://www.sierrachart.com/image.php?Image=153209677982.png Date Time Of Last Edit: 2018-07-20 14:40:06
[2018-07-20 14:56:39] |
What is the specific problem you are having in regards to that particular screenshot of the spreadsheet? You may want to select all of those cells you show in the screenshot and then go to the chart and select Chart >> Recalculate.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-20 14:57:11
[2018-07-20 15:32:02] |
no prices in second row for volume at price data and all the bars start at BA coloumn.
Date Time Of Last Edit: 2018-07-20 15:32:47
[2018-07-20 16:12:45] |
That is correct. It is working properly.
[2018-07-20 16:41:44] |
We actually do see a problem with the outputting of the Volume at Price data to a Spreadsheet and we are looking into it.
[2018-07-20 17:55:39] |
We have decided to re-implement this functionality and it will be done differently than is documented but in a more practical and usable way we think. We will have more details in about 1 to 2 weeks.
[2018-07-20 18:44:42] |
in old releases old functionality remain?
[2018-07-20 22:53:44] |
Yes.
