Date/Time: Sat, 04 May 2024 20:08:25 +0000
Missing Pulling/Stacking Data
View Count: 632
[2018-07-20 06:51:41] |
User595648 - Posts: 3 |
I use the pulling and stacking column data on my Chart DOM. Yesterday I started to see dropping and inconsistent data in those columns (see screenshot) on my ES futures chart. It was a problem no matter the symbol I had up. Anybody getting this? I tried rolling back to a previous version of software (I am on update 1781) but that did not clear it up.
Pulling Stacking.png / V - Attached On 2018-07-20 06:51:22 UTC - Size: 157.81 KB - 249 views |
[2018-07-20 16:19:21] |
Perform a Full Reset of the Symbol Settings: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps If there still is an issue, then apply the Symbol Settings for the symbol to the chart following these instructions: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
