Date/Time: Sat, 04 May 2024 15:46:16 +0000
Custom Buttons description widths v1781
View Count: 783
[2018-07-20 02:10:12] |
User553714 - Posts: 184 |
I recently updated from 64bit V1762 to V1781; After I recompile my Custom Studies and then attach them to the chart, the descriptions of the custom buttons no longer increase in width to display the entire custom button description as before. For example the Custom button description "LastTrade" only displays the middle 5-characters or "stTra" The issue is resolved by either; 1) Saving the chart with the custom studies added and then close down and restart SC; the custom buttons then display the entire button description 2) Using Window, Custom Bras to remove each Custom Bar 2, 3, 4, and then re-applying Note: I have the tick box global control settings >> customize control bar-x >> Use same size for control bar buttons >> NOT ticked Can you please change this so that button widths get refreshed as custom studies are added onto a chart as before. |
[2018-08-03 12:54:01] |
Thankyou for fixing the issue I described in V1785 which I just upgraded to; your software is simply brilliant thanks!
