Date/Time: Thu, 02 May 2024 03:42:23 +0000
Composite setting that mimics IRT software
View Count: 1105
[2018-07-19 21:31:40] |
User149226 - Posts: 16 |
Is it possible to achieve this look where I have a composite setting in the background at the same time as the micro composite (drawn profiles for the day).
GlossaryComposite.png / V - Attached On 2018-07-19 21:26:54 UTC - Size: 195.7 KB - 296 views Attachment Deleted. |
[2018-07-20 01:17:49] |
Yes. This is just a right aligned volume profile set as you require. Refer to: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
