Date/Time: Wed, 13 May 2026 10:21:38 +0000
starting spreadsheet autotrade
View Count: 1587
| [2013-10-17 17:40:01] |
| shane a mcdonald - Posts: 18 |
which part of the instructions will I find about starting and stopping autotrading with a spreadsheet system ? How to turn it on and off ? thanks shane |
| [2013-10-18 02:40:04] |
This is explained at the beginning of this section here: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#AutomatedTrading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
