Date/Time: Mon, 06 May 2024 16:55:48 +0000
Price multipliers
View Count: 843
[2018-07-18 21:03:04] |
User858758 - Posts: 14 |
We are moving brokers and have a new TT FIX session setup and are wondering if there are any price multipliers that might be messing with our charts.
[2018-07-18 21:08:13] |
In the case of using TT FIX, there are price multipliers which are used which are set to values other than 1 which are relevant but those are automatically set when the symbol of the chart is properly set to a TT FIX symbol. What particular problem are you noticing, if any? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-19 12:37:10] |
My trader noticed when we connected to the new broker the prices were all off, connecting back to the old broker they were fine. I'm guess we will have to adjust the settings in Sierra Chart to compensate correct?
[2018-07-19 14:36:40] |
What is the exact symbol of the chart?
