Date/Time: Mon, 29 Apr 2024 00:36:50 +0000
[User Discussion] - Trendline(Ray) Study
View Count: 1807
[2018-07-18 16:51:08] |
User735640 - Posts: 14 |
SC could you create a Trendline(Ray)study that will draw a moveable Trendline on a chart and will show the current price of the Trendline ie: SG1 at the current bar? I saw there is an Automatic Trendlines Study. But the user cant moves or adjust the Trendlines as needed. I`m sure you guys can whip up just a basic Trendline study that is not advanced as the Automatic Trendlines Study. Thanks. Date Time Of Last Edit: 2018-07-18 16:59:51
[2018-07-24 18:56:27] |
6 days since posting and still no response from SC support. I guess the creation of the Trend line study I requested is too difficult to build. |
[2018-07-26 16:51:26] |
Refer to: Notice: Suggestions (Currently not accepting) This would only be done for an additional cost and we would not be able to get to it for about two years. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-26 16:51:59
[2018-07-26 17:57:37] |
Thanks for the reply. Perhaps one of the coding genius on the site can produce a trend line study for users of your software. |
