Date/Time: Tue, 21 May 2024 05:04:25 +0000
Grid lines over candles
View Count: 1545
[2018-07-18 15:14:39] |
marwhitt - Posts: 29 |
How can I make the horizontal grid lines display behind the candlesticks? Right now they are over top of the candles.
[2018-07-18 17:22:55] |
You need to disable this option: Chart Settings: Draw Horizontal/Vertical Grid Above Graphs (Chart >> Chart Settings >> Grid menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
