Date/Time: Tue, 30 Apr 2024 06:14:39 +0000
Newest 32 bit version
View Count: 1103
[2018-07-17 19:35:41] |
User40526 - Posts: 166 |
My 32 bit version is 1713 on my laptop. Is that the current version? I have tried to download the current version on the laptop but it does not update the way my 64 bit version does on my desktop. Thank you |
[2018-07-17 19:53:00] |
No, the latest version is 1781. Just update Sierra Chart by using this installer: https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe Rather than through the Help Menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-17 19:53:31
