Date/Time: Sun, 05 May 2024 17:15:12 +0000
UK Natural Gas
View Count: 815
[2018-07-17 12:30:44] |
User294224 - Posts: 43 |
Hi Please could you add the following product on CQG? https://www.theice.com/products/910/UK-Natural-Gas-Futures/specs |
Capture.PNG / V - Attached On 2018-07-17 12:30:27 UTC - Size: 7.29 KB - 292 views |
[2018-07-17 18:56:28] |
Yes, we will add this.
[2018-07-18 18:05:16] |
When should it be available for? Cheers Will |
[2018-07-18 23:25:46] |
This has now been added. The symbol pattern is: F.US.QU?## Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
