Date/Time: Sat, 04 May 2024 21:25:43 +0000
Adding a second installation/DataFile
View Count: 634
[2018-07-16 21:55:52] |
User68474 - Posts: 195 |
I have added a second installation of SC to my desktop. As per instructions, I created a new folder (C:SierraChart2)for this installment. I use Rithmic Data Feed with DTC Bridge. My intentions are NOT to run the two simultaneously. I want to keep this "instance" very "lean" and kind of consolidate a lot of what I have learned about SC as a way of "organizing" myself. I'm not sure, however, of the following: Do I need to also rename the "Data" Folder in this new installment? Or is the fact that it will now be designated "C:SierraChart2/Data" enough to avoid any corruption or interference, especially if I wish to copy and paste some data from instance #1 to #2.?
[2018-07-17 01:55:11] |
Or is the fact that it will now be designated "C:SierraChart2/Data" enough to avoid any corruption or interference Yes.
