Date/Time: Sun, 05 May 2024 07:18:40 +0000
Current Trades not visible on CTS feed
View Count: 646
[2018-07-16 21:17:29] |
User993067 - Posts: 142 |
Current trades feature on DOM is not visible on CTS feed...works fine on CQG. Is the correct?...suggestions...(TST Combine)
[2018-07-17 01:18:19] |
This has been solved. Update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
