Date/Time: Sun, 05 May 2024 17:32:32 +0000
spreadsheet study not updating
View Count: 982
[2018-07-16 06:20:45] |
User523468 - Posts: 27 |
Hi SC. My spreadsheet study isn't updating its values with live market data. http://www.sierrachart.com/image.php?Image=1531721794186.png |
[2018-07-16 14:45:17] |
Make sure this Input and the following two Inputs are set correctly with the Spreadsheet Study you are using: Spreadsheet Study Inputs: Chart Data Output Specification Type Also refer this page if the chart itself is not updating: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-16 14:46:02
[2018-07-16 16:27:56] |
The chart itself was updating, the problem was with the incorrectly configured input values. I have now resolved the problem — thanks for the input.
