Date/Time: Thu, 02 May 2024 00:16:24 +0000
'Global Cursor On' not working on Detached charts with 'Window Always Visible' enabled
View Count: 782
[2018-07-15 23:46:31] |
samual sprat - Posts: 343 |
Hi I have several chartbooks open in my instance and I have charts from each chartbook detached and with 'Window Always Visible' option enabled. If I turn on global crosshair i'm noticing that the cursor is not displaying on charts from the same chartbook which are also detached and their chartbook is not in focus. May also be happening under other circumstances which I haven't tested Thanks S |
[2018-07-16 14:33:01] |
This is not supported.
[2018-07-16 16:19:13] |
But we might be able to add this without difficulty.
[2018-07-16 17:15:34] |
We found a simple solution. So this will be supported in 1782.
