Date/Time: Sat, 04 May 2024 13:36:22 +0000
Orders and Positions ERROR found
View Count: 1422
[2013-10-17 03:14:56] |
batman_ - Posts: 190 |
SC, Please advice how to correct the following 5 errors found in Orders and Position;- No.1: The latest sell price of 23428 is a FILLED PRICE? No.2: 'Filled price of 23232 at Trade Chart DOM' does not matched with '23428 from 'No. 1'. No.3: 'SELL SIGNAL from chart indicates 23242' does not matched with 'No.1=23428' and 'No.2=23232'. No.4: Significant simulation daily losses due to error from No.1, No.2 and No.3 No.5: Orders and Positions filled for buy prices always lower than sell prices, indicates a profit generated from round trips. BUT 'No.5 trades records never matched to 'No.4' which suggests a daily simulation losses. |
Private File |
[2013-10-17 09:56:01] |
another seriously error noted in chart trade mode for price entry. SELL entry price was filled at 8785.0 even though last price only reached at 8785.50(label in red). Sell signal was triggered at 8786.25 and it should be filled at 8786.00 via buy stop. Kindly review this error. |
Private File |
[2013-10-17 22:38:07] |
There are no errors here. This is CFD data you are working with. Refer to these two sections here: http://www.sierrachart.com/index.php?l=doc/doc_TradeSimulation.php#HowOrdersAreFilled http://www.sierrachart.com/index.php?l=doc/doc_TradeSimulation.php#MidpointPriceChartBars They explain very clearly how all of this works. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-18 21:01:42] |
1. The price column only has the order price. Not the fill price. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#ColumnDescriptions 3. The buy/sell signal arrow on the chart does not necessarily correspond with the order price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
