Date/Time: Mon, 29 Apr 2024 15:29:54 +0000
Range price display
View Count: 865
[2018-07-14 05:36:16] |
User376341 - Posts: 37 |
Hi Does SC have this price display, not to be confused with "Range Bars" This attached display type still uses 5/30/60 min based charting. It just shows where the price has been. jt |
Range price display.PNG / V - Attached On 2018-07-14 05:30:28 UTC - Size: 18.36 KB - 285 views |
[2018-07-16 18:00:37] |
Not exactly. You just need to use standard OHLC Bars or Candlestick Bars. These are all documented here: Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-16 19:17:16] |
Sawtooth - Posts: 3983 |
You can create this by doing the following: - Add the Moving Averages study - Set MA 1 to the Simple Moving Avg of the High with a Length of 1 - Set MA 2 to the Simple Moving Avg of the Low with a Length of 1 - On the Subgraphs tab: -- set the Draw Style of SG1 to Fill Top -- set the Draw Style of SG2 to Fill Bottom -- set the Draw Style of SG3 to Ignore |
