Date/Time: Sat, 04 May 2024 08:35:41 +0000
Numbers Bars - Calculated Values Question
View Count: 950
[2018-07-13 19:59:45] |
infpz - Posts: 826 |
Possible to add subgraph options for Highest Point of Control Value of Bar and Lowest Point of Control Value of Bar?
[2018-07-14 13:57:19] |
How do you calculate these?
[2018-07-16 13:10:33] |
So for example in a given bar, if the POC (price at which most volume was recorded) was 100, but then moved to 105 intrabar, then to 98, then at the close of the bar the POC was 99, then Highest POC value would be 105 and the Lowest POC Value would be 98.
[2018-07-16 14:34:37] |
This is definitely not something that we would develop. It is not reasonably possible to implement. This can be done now though using our standard methods which consists of the particular study you want to use which in this case would be the Volume Value Area Lines and then you need to use this particular study which involves 2 charts: Study Overlay - OHLC (Open, High, Low, Close) But this is going to be a normal study and not a table view. To be clear, as we said this is not something that we would develop and we are more than happy if people go elsewhere for this functionality. We just do not have it beyond what we have now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-16 14:36:25
[2018-07-16 14:37:34] |
Understood, I see how it could be done via that study as well.
