Date/Time: Thu, 02 May 2024 21:11:47 +0000
[Programming Help] - ACSIL: Controlling Visibility of Studies in Other charts
View Count: 2518
[2018-07-13 17:30:40] |
Jezz - Posts: 33 |
Hi Trying to code a button for hiding some studies, followed the idea described in https://futures.io/sierra-chart/26630-hide-show-studies-buttons-study.html#post346912 and found that sc.SetStudyVisibilityState (sc.SetStudyVisibilityState) only hide studies for the same chart, not for other charts. If there is a solution, I didn't I find it, and appreciate any pointer. If unimplemented, as an idea, a new function like sc.SetChartStudyVisibilityState could accept appropriated arguments to identify the study. Thanks in advance PD: The code in the above link needs a couple of tweaks in order to be compiled in recent versions: 1. Rename sc. MouseEventType to sc.PointerEventType as suggested in Problems compiling Study | Post: 95057 2. Definition of constants SC_ACS_TOOLX as X 3. Clean up the #includes |
[2018-07-13 17:47:28] |
No, there is not a function to control the visibility of a study in another chart compared to the chart the study controlling this is on.
[2018-07-15 18:53:25] |
@sstfrederik - Posts: 403 |
When hiding studies on the same chart you can you use a study in my freebundle. Get the freebundle here: https://www.simplesystemtrading.com/hide-studies/ |
