Date/Time: Mon, 29 Apr 2024 00:26:53 +0000
Order Types - Trade Volume Trigger question
View Count: 683
[2018-07-13 12:33:35] |
User7817001 - Posts: 96 |
Morning all, Based on Ver 1781 32-bit 1) Order Type Documentation terms/descriptions/labels no longer match the actual Order Menu Labels, might want to clean that up... 2) There are many great order types, including Trade Volume Trigger (which appears to actually be counting accurately now), but it would be even BETTER if Trade Volume Trigger function could be included within ALL stop choices, maybe adding a Volume Trigger option (checkbox and value field) to the menu, under and similar to 'Move To Breakeven for Stop' which is also great Thank you, Mark |
[2018-07-13 12:52:41] |
1. Give us an example.
[2018-07-13 13:30:02] |
here is just one of many, thanks
Capture.JPG / V - Attached On 2018-07-13 13:29:55 UTC - Size: 196.92 KB - 309 views |
[2018-07-16 18:14:49] |
Okay we see what you mean but there is a standardized logic used in the documentation. For example, any Attached Order setting will be prefixed with Attached Order even though the label does not show that. We will see what we can do to make this more clear. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-16 21:15:08] |
Perfecto, the explanations are great, with example text at the beginning, but the labels need to be matched, documentation is the boring part of coding, but necessary
