Date/Time: Sun, 05 May 2024 22:56:46 +0000
renko bar predictor for flex renko inverse set
View Count: 1813
[2018-07-10 11:53:15] |
User294173 - Posts: 6 |
I have a chart in flex renko inverse set, I want to put the renko predictor bar but it does not do the right level so I try to program them with the study spreadsheet formula. I want it put a level on the corresponding chart as part of a bullish preceding candle that just closed, the highest of this candle +2 ticks I tried with this formula but nothing is displayed: = IF (O [-1] -C [-1] <0, H [-1] +2) |
[2018-07-10 14:21:24] |
John - SC Support - Posts: 31379 |
There are two problems with your formula. First, the IF statement takes 3 parameters - 1: The condition to check; 2: What to return if True; and 3: What to return if False. You are missing the 3rd parameter. Second, you need to have the brackets next to the item that they are adjusting, so get rid of the spaces after the O, C and H. Your formula should look like this after you correct it: =IF(O[-1] - C[-1] < 0, H[-1] + 2, 0) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-10 15:26:54] |
i put your formula and the log said that: study spreadsheet formula is true i heard the alert but i don't have the line in the chart.
[2018-07-10 16:12:38] |
What I had given you was just the information to fix the Spreadsheet Formula Study and draw that particular study. I take it you need more information, but I need to understand exactly what you are trying to do. Just the simplest description of what you want to see on your chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-10 18:57:11] |
I have a flex renko inverse set chart, I would like to put the renko predictor bar but it does not doone the right level for the flex renko inverse. Can you do a study: flex renko inverse bar predictor for this type of flex renko?
Date Time Of Last Edit: 2018-07-10 19:03:30
[2018-07-11 16:08:18] |
We are looking into this and will let you know here.
[2018-07-13 14:36:08] |
Did you look into this?
[2018-07-13 15:53:33] |
Yes, it is still being reviewed.
[2018-07-16 18:14:00] |
The Renko Predictor study will be updated to support Renko Bar Inverse settings.
[2018-07-16 19:01:56] |
Xfanman1 - Posts: 320 |
Engineering, I've attached images below of my modified version of the Renko Bar Predictor that has added inputs for multiple targets and/or offsets. I find this VERY useful when choosing entry location and targets. If you haven't finished the update to this study yet maybe other users would find this added flexibility useful. Thanks! -- Scott Date Time Of Last Edit: 2018-07-16 19:02:43
Renko Bar Predictor.PNG / V - Attached On 2018-07-16 19:01:44 UTC - Size: 57.67 KB - 551 views Renko Bar Predictor Subgraphs.PNG / V - Attached On 2018-07-16 19:02:40 UTC - Size: 47.9 KB - 359 views |
[2018-07-24 05:58:41] |
User538995 - Posts: 11 |
Hello, the new renko bar predictor is it available for the new version of sierra? because i downloaded the version 1783 but putting the renko bar predictor it is always wrong for the Renko Bar Inverse. |
[2018-07-24 14:42:47] |
No, it is not yet available. We should have it done within the next week. We will post here when it is available.
[2018-07-27 18:35:04] |
Sorry for how long this has taken, we have just been busy with lots of things. We have updated the Renko Bar Predictor study to handle the Inverse settings. We have not added any additional functionality at this time. The updated study will be available in release 1785. When the Pre Release is available, you can update to the latest version by following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
